SOS supercharger 3.2 pulley pump gas AP1
I’m running a novi1200 3.6 on a SOS pulley (no extra idler pulley) making 9-10 psi on 93 on my ap1, on a 365 WHP street tune
Mods list:
AEM v2
Fujitsubo power getter
Berk HFC
Upgraded heat exchanger
Bosch 1000 cc injectors
Walboro 255
Act clutch kit
AEM x band AFR gauge
Tial BOV
I want to upgrade for more power & im considering upgrading to either the 3.4 vs 3.2 griptec pulley. I know the 3.2 starts over revving past 8.4k rpm but I hear some people are running it & it’s ok. I want to stick to 93 but I don't want to lose the 9k redline and rather not have fuel cutoff past 8.4k rpm. Anyone running the 3.2 on an ap1 with pump gas share their experience and also how much power you're making?
Mods list:
AEM v2
Berk HFC
Walboro 255
Act clutch kit
Tial BOV
Again. Send it.
Understand, in my and most cases, these are street cars. Even if you spent a lot of time in the upper rev range on track or anything else, how long are you actually staying within the overspinning territory? (Let's say....past 8500 rpm) Mere seconds. If this was sustained I'd feel differently about it. Just know, chasing power is addicting, and especially in the case of superchargers (imho), you really gotta just fully send them right out of the box....Unless you're making in excess over 400whp right off the rip with a supercharger, you're most likely very underwhelmed and bored. I'd encourage anyone running a centrifugal supercharger to just max it out within reason (returns diminish HARDCORE after x amount of dollars; get the smallest realistic griptec pulley, run on flex fuel, and just get it for all its worth)
Also, add that additional idler pulley now.
You could also get tuned on Boostane or race fuel or E85 and make noticeably more power (arguably more than with adding 1 - 2 psi) with more aggressive ignition timing.
Also, to what Kyle stated - if you do go with crazy small pulley, it's good for low end and you can either not spend a lot of time in the overspinning area or even drop your redline a little.
vasol
Sep 25, 2021 06:45 AM
