Spun bearing
Old Apr 17, 2011 | 02:46 PM
bois2k's Avatar
about 1800 miles on the motor car was running fine and the afr looked ok
Old Apr 17, 2011 | 02:52 PM
wadzii's Avatar
Banned
Just BC the afr was ok doesn't mean there wasn't detonation.
Check the plugs and bearings for signs of detonation
Old Apr 17, 2011 | 03:05 PM
bois2k's Avatar
oh ok what should i look for? and what would cause that a bad tune?
Old Apr 17, 2011 | 06:40 PM
wadzii's Avatar
Banned
on the bearings, look for the back side of the top bearing to be black, this indicates extreme pressure from detonation. Basically the shock crushes the bearing little by little and allows it to move around in the rod. The movement causes them to turn black.
You can google for pics of what spark plugs with detonation look like.. or if you can get some good pics maybe we can tell. They will look like they have bits of aluminum sort of "sprayed" on, they will be fuzzy with aluminum on the ground electrode and porcelain.
Old Apr 17, 2011 | 07:14 PM
bois2k's Avatar
ok thanks alot man il take it apart tomorrow morning and take some pics!! hope thats not the case=(
Brannonanand
Apr 25, 2016 11:23 PM
Oombop
Jan 5, 2012 06:30 PM
kent876
Sep 29, 2011 01:06 PM
ChefJ
Jul 31, 2010 06:11 AM
mikecl713
Jul 19, 2004 10:34 AM
