Stroking the Engine
Old Mar 26, 2013 | 03:56 PM
boostedf20c's Avatar
Originally Posted by wildkart
Originally Posted by boostedf20c' timestamp='1364176942' post='22425748
I hope so car peaked at 509rwhp@19psi on 93 so I am hoping to break 550 on pump, over 700 on race gas fingers are crossed
What injectors and fuel system are you runnning? Also look into a spark booster.
That would be the only reason that you would not hit the numbers. I make 651 on race gas, but thats only cause i ran out of spark and fuel. I am running 1000cc injectors with stock likes and rail.
hope that helps.
Thank you for the input, I believe I am running 1000cc as well but I would have to double check, also running stock fuel lines and rail, but that is going to change before it makes it to the dyno. Going with a custom setup and bigger rail so I have my fingers crossed.
Old Mar 27, 2013 | 08:54 AM
wildkart's Avatar
Originally Posted by wildkart' timestamp='1364320545' post='22429781
[quote name='boostedf20c' timestamp='1364176942' post='22425748']
hope that helps.
[/quote]
Look into a spark booster.. My problem was not my fuel more than it was my spark I maxed out at 651 because i ran out of spark.. Look up JMS Powermax Sparkmax.. its like $349 and will be worth every penny. It is my next purchase when i switch to E85.
Old Mar 28, 2013 | 04:01 PM
Thanks for the information I will definitely be looking into that before the car is put on the dyno.
mr-pitts
Aug 24, 2016 10:10 PM
Sticky2k
May 28, 2014 02:05 PM
Batbite
Jun 23, 2012 12:47 PM
aitrus16
Aug 30, 2010 04:56 PM
pie
Jan 25, 2008 02:27 PM
