The Struggle is Real...Another KW Kit Issue
Old Aug 14, 2015 | 04:04 AM
  #101
pwrinxs's Avatar
Originally Posted by braeden
The fact that you're encouraged to shave down the steering rack by the manufacturer is a joke in itself, thank god I bought the SOS kit
Come on man...statements like this are not really helpful. If our SOS kits had problems, sure there would be a hater or two chiming in but a lot of the folks posting about the KW kit or running the KW kit themselves are knowledgeable and contributing members of this forum and they would come to our aid. Its no good to make them feel worse or more anxious; we should all complain to KW instead. Wish Kw would post more often and be more involved in this process.
Old Aug 14, 2015 | 05:18 AM
  #102
CRVRX's Avatar
The reason you are encouraged to shave the rack is more for installing the belt. The cogged belt on the Kraftwerks kits wider than needed so the belt will not be too close to the edge and cause damage.
I like the cogged belt as it requires less belt tension and causes less less side load on the pulleys including the Crank shaft.
Most aftermarket parts do require some kind of trimming somewhere.
Old Aug 14, 2015 | 09:35 AM
  #103
s.hasan546's Avatar
useless post. & the TTS kit requires it too.
Old Aug 14, 2015 | 12:27 PM
  #104
The Machine's Avatar
Habit, here are some pics I took of my crank pulley and the rack. Looking at the crank pulley itself, I only saw a few little silver marks along the outer part of it. So I am guessing that this didn't make full contact with the rack when the belt broke. That bolt looks like it has been shaved some on my car as well. Now I'm not sure if the shop did it during the install or if at some point the crank pulley actually contacted it. Since I had that bolt break initially, all new pulleys were sent to me. So maybe when that bolt broke the old crank pulley contacted the rack. I also included one to show that I guess I am missing part of the under body plastics.
Missing plastic piece:
Pics of the pulley and rack bolt:
Old Aug 14, 2015 | 01:46 PM
  #105
braeden's Avatar
I agree, it was a useless post but everyone is allowed at least one out of hundred right?
I just don't believe in irreversible modifications to the car. I would not have even contemplated buying the SOS kit if I knew that you had to modify the steering rack, but hey, that's just me.
I hope you guys can get all these problems sorted out
Old Aug 14, 2015 | 02:54 PM
  #106
Memo6453's Avatar
I'm excited to have the KW kit installed. Hopefully within next 2 weeks.....
Old Aug 14, 2015 | 04:28 PM
  #107
chefs2000's Avatar
Originally Posted by The Machine
Habit, here are some pics I took of my crank pulley and the rack. Looking at the crank pulley itself, I only saw a few little silver marks along the outer part of it. So I am guessing that this didn't make full contact with the rack when the belt broke. That bolt looks like it has been shaved some on my car as well. Now I'm not sure if the shop did it during the install or if at some point the crank pulley actually contacted it. Since I had that bolt break initially, all new pulleys were sent to me. So maybe when that bolt broke the old crank pulley contacted the rack. I also included one to show that I guess I am missing part of the under body plastics. Missing plastic piece: Pics of the pulley and rack bolt:
Mine hit A lot more than that and did not affect my belt ...and the belt is a good amount away from the pulley edge ..my feeling is pre damaged belt
Old Aug 14, 2015 | 05:07 PM
  #108
Yeah I'm thinking so too Chef. When watching the engine run and even in the pics I posted, my belt is perfectly center on the crank pulley, so even if it were to have touched that steering rack bolt, I doubt the belt would have made contact with anything.
I should also note that I did receive the package KW sent on Wednesday morning and when I opened the box, much to my surprise, they included 2 belts instead of just sending one. So I was actually very happy to see that.
Old Aug 14, 2015 | 05:18 PM
  #109
Habitforming's Avatar
Many of us haven't had to. I have more clearance than he does, without any modification.
Old Aug 14, 2015 | 05:54 PM
  #110
R00567's Avatar
sell your KW kit and go TURBO :-D
all joking aside, sorry to see your car down and having problems man!
it is seriously no joke how many KW kit complaints i see on the FI forum over the course of a week :-/
its most def steering me to the dark side i.e. turbo kits
