The Struggle is Real...Another KW Kit Issue
If it's worth anything; I've had those same VTEC mounting bolts snap on me (well, one of them anyway) on an SOS Stage 2. I had to buy new bolts through the Honda Motorcycles department and they're fine now
The amount of torque I put on the bolt that snapped was minimal, I was very shocked to see that it had snapped. I learnt from my lesson and used a 8-24 Nm 1/4" torque wrench the next time around.
I'll be ordering the Ti bolts and use safety wire like rain h8r suggested.
My VTEC bolts also backed out and then the front two broke. This happened at about 500 miles. Like Rain, I typically don't use a torque wrench for this size bolt but usually overtighten them by feel. I got replacement bolts and a gasket from KW, and this time used a torque wrench to tighten them to the Honda spec which is 12 N-m. (12 N-m is 8.85 ft-lb.). I now have 1200 miles with no other issues but I have not yet tracked the car with this kit either.
I wonder if any of these VETC bolts have come loose after being tightened with a torque wrench.
It seems to me that a simple solution would be to use loktite on them. The problem does not seem to be that the bracket is not strong enough or that the bolts aren't strong enough, it seems that the problem is that the bolts vibrate loose on some cars.
I also want to add that i track my SOS kit regularly and never had this happen until i crashed. SOS mounting brackets have rubber isolaters that help dampen vibration. Does the KW have any dampening?
Kw take care of this comon probleme , my friend broke them on is ap2 as well , call kw and they send them upgrade bold stronger and it fix the probleme
i have a question for my with the kit , did whe need to rewire de fuel pump with the graams pump provide in the kw kit ?
Also I'm selling my grams pump and using either a FB or AEM. Their cheap.
Do it right the first time and you'll have less issues/things to worry about.
Just a little update. The car was inspected today and all of the pulleys were fine and intact. The supercharger was also spinning freely. CJ promptly responded to my email this morning and they are shipping out a new belt.
