Supra PCV install DIY
Originally Posted by CIVICTOS2000,Aug 6 2007, 05:52 AM
Good Info
doing this tonite
D.
BTW the AP2 PCV does look a lot different and "stronger"...
D.
So, 9/16" to 3/8", or maybe even 5/8" to 3/8". You're going to have to play with this a bit. Once I figure this out I'll post back.
Quick question.... I got everything yestarday and I was getting ready to install it but I decided to chech the valve and blow in it to see how it works and it looks like I can get air to pass in both ways... well from one side is a lot harder but I can still get some air through it ....does that mean the PCV valve might be bad? or is that normal? thanks in advance...
D.
D.
Hmm. That valve should be pretty strong, I personally couldn't get it to budge one way. I would say this is suspect. Your engine is pushing more air than your lungs are so I'd be cautious.
Is this the Purolator valve or a different one?
D.
