Supra PCV install DIY
Old Aug 7, 2007 | 08:05 AM
  #21
hokies2000's Avatar
That's what I would do. I noticed that the packaging on mine looked as though it had been laying there for a while. Let us know if it's better when you get the new one,
Old Aug 7, 2007 | 08:26 AM
  #22
overlord's Avatar
How do I set this up if my car has a catch can and an SC? Is the catch can still needed at this point?
Old Aug 7, 2007 | 09:00 AM
  #23
WolfInSheepsClothing's Avatar
Nice writeup
Old Aug 7, 2007 | 11:09 AM
  #24
hokies2000's Avatar
Yes. This valve won't reduce or prevent oil that escapes the crankcase from getting into the intake manifold. I don't have a catch can yet, but I can tell you how it would be plumbed at least:
From valve cover to input of catch can, from output of catch can to Supra PCV, from Supra PCV to intake manifold.
Old Aug 7, 2007 | 11:47 AM
  #25
overlord's Avatar
Thanks!
Old Aug 8, 2007 | 11:02 AM
  #26
bigpurp's Avatar
Originally Posted by hokies2000,Aug 5 2007, 06:28 AM
This accomplishes the exact same thing the krankvents do, although at a tenth of the cost!
Not quite.
While your setup will prevent boost into the crankcase, it will not create a vacuum in the crankcase (which the krankvents do). The jury's still out on whether that's a true benefit or not. Some have reported a decrease in oil consumption, and surmise that such a vacuum will create a better seal b/n pistons & rings.
Old Aug 8, 2007 | 11:19 AM
  #27
AirborneS2K's Avatar
My experience is that too much vacuum in the crank case = bad, which the front crank vent seems to cause.
Old Aug 8, 2007 | 11:58 AM
  #28
bigpurp's Avatar
So I take it you've had the krankvents on your car?
What "bad" things happened?
Old Aug 8, 2007 | 05:21 PM
  #29
hokies2000's Avatar
Hey guys,
so a 5/8" to 3/8" reducer will work. Problem is, so far I can't find a plain old reducer. I had to use two barbs and a coupler. So it makes for a hefty piece of brass to get all the tubing joined. I'm the hunt for the right reducer. Once I find it I'll post again.
Old Aug 8, 2007 | 05:37 PM
  #30
NFRTurboTerror's Avatar
I also used a supra pcv valve... no complants here.
