Tech 2 7lb pulley for comptech
Old Feb 14, 2006 | 02:00 PM
r_duff's Avatar
Default Tech 2 7lb pulley for comptech
I'm considering buying a tech 2 7lb pulley.
This pulley is designed to compensate for the .5lb loss caused by an aftercooler. I bought my kit used, and the FPR has never been messed with. As far as I know, the kit has always been installed with the AC.
My question is... can i pop this pulley right in and NOT have to mess with the FPR?
Old Feb 14, 2006 | 04:08 PM
John_Z's Avatar
Duff, you could install the pulley, but will need to dyno and get an a/f reading. It's possible to "tune" the a/f by adjusting the fuel pressure, but this must be done on a dyno or with an in-car wideband 02 sensor/gauge. It's also important to know your injector duty cycle. I think stock injectors are good till about 320rwhp. You might be able to get by with upping fuel press and vfac.
Old Feb 14, 2006 | 09:44 PM
djweaver's Avatar
You may want to Dyno first then consider installing pulley.
I have the same setup. I bought the pulley but dynoed first and found I was getting 7 psi without it.
Old Feb 16, 2006 | 05:57 PM
r_duff's Avatar
thx for the imput fellas.
Old Feb 16, 2006 | 06:31 PM
j_c_a's Avatar
Be careful. I'm actually getting as much as 8 lbs from that pulley depending on weather conditions. And you definately do need some tuning for that. I wasn't comfortable w/ my A/F's using just FPR adjustments. I ended up getting a vafc.
Old Feb 16, 2006 | 08:42 PM
FF2Skip's Avatar
I ran the 7# pulley before upgrading. No VAFC, but the FPR was adjusted on the dyno. Stock injectors can handle it, but it's close to maxxing.
Old Feb 16, 2006 | 08:49 PM
dfneva's Avatar
just to clarify, you can tune just by adjusting the FPR?
emanage or aem ems is not needed for the 7lb pulley?
jdmdohcpower
May 18, 2009 12:28 PM
DEEZ
Mar 12, 2006 04:40 PM
Nick32
Oct 5, 2005 06:29 AM
LonS2k
Sep 25, 2005 12:48 AM
FF2Skip
Oct 11, 2004 08:13 PM
