Is there a max PSI on a log manifold?
Old Sep 18, 2012 | 07:58 PM
alanpikku's Avatar
I hit 552 hp on my log manifold on 23 psi using e85.The issue with logs are exhaust gas reversion since the f20/22 flows so well. This means you will lose midrange due to vtec being set higher. Logs are not a bad setup for lower numbers though. I went to a forward facing setup, and it is a night and day difference. Made the same power on 5 psi less boost and regained all the midrange due to vtec being set lower. I was able to hit 375 hp on 91 octane on 11 psi on a t3/60-1. You should be able to hit 400 hp, but that is probably the MAX I would push on a log manifold using pump gas.
Old Sep 18, 2012 | 08:02 PM
camuman's Avatar
Did u log knock?
Old Sep 18, 2012 | 09:25 PM
s2000Junky's Avatar
Yeah, in the toilet
Old Sep 19, 2012 | 05:09 AM
rikhemi's Avatar
Nope my tuner didnt setup the knock sensor setup on the aem. So that is my only concern.
Old Sep 19, 2012 | 05:47 AM
Vi3tBoy's Avatar
I made 400 on a fbm log on 91 octane at 13PSI with a garret t3/t4 60 trim.
Then at 20psi on E85 made 500+
Possible? YEP
Old Sep 19, 2012 | 11:09 AM
sohc_mshue's Avatar
515whp on a log running e85 here.
Old Sep 19, 2012 | 11:32 AM
rikhemi's Avatar
Nice numbers.. Ok will do some street tunning and then see when I can go to a local dyno day.. 400 to the wheels is my goal.
Old Aug 28, 2013 | 11:21 AM
KaNgArOo's Avatar
Bringing a dead thread back. Contemplating installing my Inline Pro stage 1 kit this coming spring. Hoping to make 450whp with my Precision 6165BB turbo with .63 exhaust housing. I have a question though. I am going to do a V-band exhaust housing, so I was wondering if i could just order the bigger .83 v-band exhaust housing, and will it fit my turbo.
I'm new at this turbo stuff, so is it possible to switch A/R housings with these turbos???
Old Aug 28, 2013 | 06:05 PM
S2kserry's Avatar
damn i have a pfab log mani at 14psi making 365hp. thats with a gt3076r, 750cc injectors. my exhaust housing is probably whats holding me back i suppose.
Pokemon
Aug 12, 2016 11:39 PM
chubbys2k
Aug 5, 2015 04:04 AM
H4RD ON
Jan 24, 2012 06:25 PM
Suzuka-S2K
Sep 10, 2010 07:07 AM
B5254T4
Jan 24, 2010 03:29 PM
