Things required/recommended for SCing?
Old Apr 13, 2013 | 07:21 PM
OemEF's Avatar
Default Things required/recommended for SCing?
I am considering buying a friend's vortech centrifugal charger for my bone stock 00. I want to have a list of everything I will need to get the car going before I make the decision. I know I will need:
- the Supercharger
- Larger Injectors?????
- EMS
- Been planning on doing AP2 retainers and keepers
- ARP Headstuds (Just to be on the safe side)
- intercooler???
Am I missing anything?
Old Apr 13, 2013 | 09:56 PM
leo520's Avatar
No need arp
No need inter cooler.
Uh r good to go with bigger injector n ems.and a good tune
Old Apr 13, 2013 | 10:38 PM
s2000Junky's Avatar
Yeah keep the water/air after cooler. FMIC isn't good on a SC, too much boost loss and poor throttle response. A good size heat exchanger will be sufficient.
Do not mess with the head studs, stock is fine. Your better off leaving the motor alone.
If your planning on running more then 10psi, you will need a map sensor. 3 bar will do.
ID1000 injectors are proven and highly recommended.
Old Apr 14, 2013 | 01:58 AM
liquid_helix136's Avatar
Depending on how much boost your gonna push, you will need the pulley / belt for that psi, ems, bigger injectors, map sensor and a fuel pump. I also hear that an upgraded heat exchanger is considered a necessity if you are going to a high boost set up, which requires the large heat exchanger and a bigger water pump.
Need more details of what your goals / plans are to really give you a better answer
uhohitzluke
Oct 4, 2017 04:48 AM
erikvanden
May 13, 2011 07:21 PM
chairmnofthboard
Sep 20, 2007 11:43 PM
Erick S
South Florida
16
Jan 26, 2007 10:10 AM
r_duff
Oct 28, 2005 09:41 AM
