Thinking of welding dump toob into exhaust..
Old Sep 30, 2009 | 05:58 PM
  #31
goldsS2000's Avatar
wtf? ej25?
*edit: read the rest of your post
Old Oct 1, 2009 | 06:36 AM
  #32
HMFIC's Avatar
Originally Posted by EngineerX,Sep 30 2009, 05:59 PM
One suggestion,
ask the fabricator / weld shop to make the dump tube as tangential as possible to the downpipe tube.
Avoid the easy 90* weld. Some shops will just make dump tubes that are perpendicular to the gas flow direction in the exhaust stream. Gases don't like right angles!
It will require extra work as you have to cut the pipe at an angle and cut an elliptical hole in the downpipe, but it will flow better as the gases will meet at a smaller angle of incidence as opposed to a 90* angle
here you can see how I did mine (top) for my Subaru. the tube joins the downpipe at a small angle, the bottom pic is what shops like to do as it's easier to cut a pipe in a straight section and make a round hole in the dpipe, then weld.
ahhh.. i see..
hmm i wonder if Ptuning is capable of doing so. when someone told me it sounded like i was draggin metal on the ground when i was going WOT, I was like....uh no.. lol
Old Oct 1, 2009 | 06:48 AM
  #33
spectacle's Avatar
Originally Posted by CKit,Sep 27 2009, 02:03 PM
Lol at dump TOOB.
I can't stop laughing at this. Not a knock on you OP, but its just funny to imagine it being said like that lol
Old Oct 1, 2009 | 06:49 AM
  #34
spectacle's Avatar
Originally Posted by HMFIC,Sep 27 2009, 09:09 PM
oh really? wait what does your butt dyno say?
I never had the car with an open dump so I can't compare.
Old Oct 1, 2009 | 08:24 AM
  #35
EngineerX's Avatar
Originally Posted by HMFIC,Oct 1 2009, 06:36 AM
ahhh.. i see..
I don't see why well established shop wouldn't be able to fab up something similar. Heck if I can hack 2 pipes and make them fit like this, then any half decent shop should be able to do it. It should be no more than 2 hours worth of work. It's the best way to merge 2 pipes and have a less turbulent flow
Remember, you are the paying customer so you tell them what you want.
This is what the pipe cross-section will look like. You can have them merge it just before the 2nd bend (just before the dpipe flange that mates to the cat converter section). Stop your buddies from bugging you about grinding screaming metallic sounds under your car! Do it !
Old Oct 1, 2009 | 10:02 AM
  #36
HMFIC's Avatar
Old Oct 1, 2009 | 10:03 AM
  #37
HMFIC's Avatar
but it pulls all the way right? i mean you dont feel any hesitation or it slowing down then picking back up do you?
Old Oct 1, 2009 | 10:05 AM
  #38
HMFIC's Avatar
Gotcha..
i'mma have them take a look and see what they say...
i feel like i dont wanna go WOT just because i'm tired of hearing it lol
Old Oct 1, 2009 | 10:57 AM
  #39
//steve\\'s Avatar
shouldn't loose too much power from doing it as long as it's done right. Like others have said make sure it flows back into the downpipe smoothly. Also the farther downstream from the turbo the better.
Old Oct 1, 2009 | 11:58 AM
  #40
HMFIC's Avatar
hmm... i wonder if they can pull that off..
Oh.. and the folks that have done this... when the WG starts dumping... *after welding the dump toob into the downpipe* did the noise completely go away? or did the exhaust sound kinda loud still?
