Tial waste gate
Old May 20, 2012 | 03:37 PM
05TurboS2k's Avatar
Still confused on the regulator part, the entire WG is a regulator rather.... the top port should be atmosphere the side port should be to your vac/boost lines.
Old May 20, 2012 | 04:14 PM
shift9k's Avatar
Vacuum regulator/boost controller it wasnt holding vac just pulling full vac straight to top port on wastegate so I disconnected the boost controller.
So I should now still have a vac line with full vac to the side port? I can not leave both top and side ports to atmosphere?
Old May 20, 2012 | 04:18 PM
05TurboS2k's Avatar
AHHHHH Boost controller, ok. Got it.
No you can't leave all the ports open. Now you should have just a line going to the normal side port to vac/boost lines, the top port stays atmosphere (unused).
In a perfect world that vac line would actually go to the cold side turbo housing or directly tapped into the charge pipe just after the turbo for best response. ID6mm according to Tial though I've had ok luck with half that.
Old May 20, 2012 | 05:11 PM
herecomesboost's Avatar
http://www.newcougar.org/gallery/fil...ate_vacuum.gif
Old May 20, 2012 | 05:14 PM
05TurboS2k's Avatar
^ Exactly, without the boost controller (as pictured *AEM/MAC solenoid*) you'd just simply avoid the "T" fitting that goes to the solenoid and run the bottom port as shown.
This shows the cold side turbo tapped for pressure as is preferable, though few do it, it provides better WG response.
Old May 20, 2012 | 05:55 PM
shift9k's Avatar
Awesome thank you guys just need to mount gauges fix a small oil leak from oil filter relocate and get tuned
Old May 20, 2012 | 07:31 PM
05TurboS2k's Avatar
Check everything over a few times before you hit the dyno, things like air bubbles in the coolant system, things like oil leaks etc.
GL man!
s2konroids
Aug 19, 2014 06:45 AM
swifbboy
Sep 7, 2012 08:10 AM
YuriArts
Feb 28, 2008 09:33 PM
syellow
Nov 14, 2007 01:31 PM
ideugene
Aug 11, 2005 09:55 AM
