Transmission?
Old Mar 29, 2011 | 12:22 AM
  #21
godmachine's Avatar
Originally Posted by redboost10
s2king is running 7.50's at 179 with the ppg gear set, i think itll hold for the most part. this gear set is about 8k but still gotta clutch and still uses the stock trans case so there are limitations to it. anytime you put an aftermarket gear set in a stock case, it eventually becomes an expensive bandaid.
cant really put a gforce in a daily driver. more fabrication required including an adapter plate and aftermarket bellhousing. but no clutching necessary and indestructible for the most part.
s2king runs liberty.
PPG synchro set which is leaps and bounds better than a stock gear is only about 5k
Gforce trans can be clutch assisted and h pattern just depends on which ya get.
Old Mar 29, 2011 | 05:32 AM
  #22
passmans2kny's Avatar
can someone make an affordable tranny option already, I'm scared I'm just gonna blow mine up
Old Mar 29, 2011 | 07:33 AM
  #23
redboost10's Avatar
s2king did run a ppg gearset in a stock case.
i know the options with gforce, if a gated clutchless trans is an option (which it is) why would anyone get anything else unless you cant per the rules of some sanctioning body? i wouldnt trade my gforce for anything
Old Mar 29, 2011 | 08:05 AM
  #24
TerminatioN's Avatar
Don't the clutchless transmissions require a ton more maintenance and upkeep?
Old Mar 29, 2011 | 08:12 AM
  #25
redboost10's Avatar
No. Not at all. We have 4 seasons on ours. Never been opened. Just fluid changes. Pressure plate requires some adjustments every now and then.
Old Mar 29, 2011 | 08:15 AM
  #26
siadam's Avatar
There won't be one. The civic guys, most of which have been around for FAR longer really don't have anything "cheap" to date.
It's a no win situation.
Basically only thing to do is upgrade to a completely different platform.
Old Mar 29, 2011 | 08:19 AM
  #27
How often do you have to change the fluid?
Old Mar 29, 2011 | 08:26 AM
  #28
redboost10's Avatar
I change mine twice each year
Old Mar 29, 2011 | 09:29 AM
  #29
and u said these are no good for a daily, or a weekend car?
Old Mar 29, 2011 | 09:44 AM
  #30
redboost10's Avatar
They make the gforce in a h patter to be more street friendly. Mine is gated. They are straight cut gears which are noisy. I drove my civic with a liberty trans on the street just fine.
The gforce is just a gear box. It requires some custom fab with an adapter plate and aftermarket bellhousing.
Whereas the ppg is a gear set that you slap in the stock case. In my opinion these gear sets that swap right into the stock case are just band aids. Just like the liberty I had on my fwd civic.
