Tunning problems, chime in **updates**
Old Aug 22, 2009 | 09:42 AM
  #21
DeadZero's Avatar
Go to a different Tuner. Thats your problem. detonation doesn't happen because of the exhaust.
Old Aug 22, 2009 | 03:10 PM
  #22
wadzii's Avatar
Banned
detonation because of a plugged cat can and does happen.
Old Aug 23, 2009 | 06:57 PM
  #23
jari8378's Avatar
UPDATE ****
SO i went to church automotive, and sean wasnt available.. TOD completed my tune(50 min). My new problem was that my clutch was slipping(on a greddy kit?) at around 6grand and he was not able to work out the issue. He stated that i need to switch to a stage 2/3 clutch and bring the car back. He stated that the car is still wanting to detonate at 6 grand(not sure why)... his only suggestions was to get a larger exhaust since i already have a TP.
My plan of action now:
-get a clutch
-get a berk HFC and probably a invidia v3(as this seems to work well)
then get a retune somewhere else....Anyone want to give me their maps? so i can use temporarily?
Old Aug 23, 2009 | 06:58 PM
  #24
jari8378's Avatar
Originally Posted by wadzii,Aug 22 2009, 08:10 AM
if the base is black afr is good, if the tip is white then thats typical of timing/heat issues.
lower egt's, or run a colder plug
i am running 1 step colder already from stock, i dont think i should go colder...
Old Aug 23, 2009 | 07:43 PM
  #25
TRBOKEV's Avatar
I honestly don't think you need any exhaust or cat change.
A test pipe and stockish exhaust should be prett good with the greddy kit.
Old Aug 23, 2009 | 07:57 PM
  #26
camuman's Avatar
Originally Posted by jari8378,Aug 23 2009, 10:57 PM
UPDATE ****
-get a clutch
if u have a test pipe then there is something else WRONG with the car. i made 300+ on a test pipe and stock exhaust. they are chasing the wrong stuff.
Old Aug 23, 2009 | 08:13 PM
  #27
TRBOKEV's Avatar
don't waste your money on exhaust and cat..
I'll send u the file tomorrow.
Old Aug 23, 2009 | 08:15 PM
  #28
jari8378's Avatar
Starting to get frustrated....
Old Aug 23, 2009 | 08:28 PM
  #29
wadzii's Avatar
Banned
send me your calibration, maybe something is wacky with it.
going too cold is better than too hot on a plug. I always start with what i think is a heat range too cold, then go from there. a plug thats too cold will just foul up, a plug thats too hot will melt your pistons.
Old Aug 24, 2009 | 07:08 AM
  #30
TRBOKEV's Avatar
Welcome to the Greddy turbo, or more correctly the E manage ultimate..
