Turbo flutter
Old May 4, 2014 | 05:52 AM
jpetch05's Avatar
Default Turbo flutter
Does anyone get any kind of flutter around 4/5 lbs due to the bov not opening ? I haven't touched my lines on that side all winter and I'm thouroughly confused. I re checked te lines. Nothing is ripped or torn. I took the BOV OFF and spring pressure seems the same (not stuck or anything).
Possible coupler leak could cause this maybe ? Anything besides coupler leak or a dead 1 year old turbo smart race port ? Lol. Again all the lines running around aren't ripped or torn.
Old May 4, 2014 | 05:55 AM
jpetch05's Avatar
I'm too scared to see if it flutters above that boost lol.
Old May 4, 2014 | 06:50 AM
jpetch05's Avatar
Opened te BOV. Diaphragm is intact. Everything seems good Smh
Old May 4, 2014 | 07:21 AM
cujet's Avatar
Sounds like compressor stall at low flow rates. While it's not ideal, it's also not a problem at low pressures and flows. This is one reason why larger turbo setups keep the BOV open under low load conditions.
My car does this under certain conditions. The original setup had the BOV open under all conditions up to and including 70MPH cruise down the highway. The problem, as I discovered, is that the car was quite unresponsive, as boost was being dumped and it took too much time for it to build up.
So, I increased the spring pressure as a "quick fix".
I have other plans for managing the BOV in the future, using a specifically located port in the throttle body. One that the throttle plate uncovers at a certain angle. Done properly, this will work just fine to manage the BOV the way I want. But, yes, I get some of those sounds under low loads.
Old May 4, 2014 | 07:45 AM
jpetch05's Avatar
Thank ya. At what boost would you imagine I should hit to see if it is still flutter or not.
Old May 4, 2014 | 09:22 AM
APoner's Avatar
Id look into a synapse unit.
They hold over 60lbs of boost and have on the the fastest reacting valve. Ideally in a very efficient turbo set up u should be open at idle and cruise to bleed excess boost (like a supercharger)
http://www.youtube.com/watch?v=MU5Y6d9rh1k
see vid
has pretty cool explination
9k4days
Dec 31, 2015 09:32 AM
klein1223
Jul 23, 2010 06:31 AM
P'sS2k
May 8, 2008 10:13 AM
YuriArts
Feb 28, 2008 09:33 PM
ideugene
Aug 11, 2005 09:55 AM
