turbo install problems
Old Nov 18, 2013 | 09:29 PM
jfd003's Avatar
Default turbo install problems
My linkHas anyone else run into problems with oil relocation not having enough room because of turbo?
Old Nov 18, 2013 | 09:55 PM
riceball777's Avatar
This is very common with turbos and the s2000. You need a oil filter relocation kit. I recommend the inline pro one becuase of the the great figment.
Old Nov 19, 2013 | 06:13 AM
jfd003's Avatar
I have a relocation kit but when trying to put it on it hits the turbo and I can not tighten it up. Also looks like there is not enough room for the hoses.
Old Nov 19, 2013 | 06:19 AM
ScienceofSpeed's Avatar
Former Sponsor
This may be a solution. There is a template provided to check fitment.
http://scienceofspeed.com/products/e...ilter_adapter/
Old Nov 19, 2013 | 08:40 AM
herecomesboost's Avatar
Which relocation kit (block) are you using? I'd recommend ditching the water section completely; use a civic oil filter holder (http://www.amazon.com/Honda-90015-PH.../dp/B00AJUZPGA). Using the aforementioned setup will give you the requisite clearance.
ZSAK
Oct 7, 2010 11:44 AM
DFWs2k
May 19, 2010 08:06 AM
josserman
Jun 1, 2009 07:33 AM
NA_Ted
Jul 15, 2008 10:17 AM
