turbo issues - #1 boost creep/spike
Old Aug 13, 2009 | 05:20 PM
Deception's Avatar
Default turbo issues - #1 boost creep/spike
Im having a few issues with my setup.. one thats scaring me the most is the boost creep. Car is tuned for 8psi. Sometimes it will get to 10 -12 psi.. this could be due to my exhaust being a 63mm..
But when im just driving normal, turbo isnt even spooling.. it has hit 19 psi on the gauge. Or it will float around in boost when im not even doing anything. What gives? Maybe something with the vaccuum lines?
Everything looks like its done right. Line off the wastegate to intake mani.. line off BOV to intake mani.
Any ideas?
Old Aug 13, 2009 | 05:25 PM
Artisan7471's Avatar
line from wastegate should not go after the throttle body, maybe thats your problem? As for boost spike what gage are you using?
Old Aug 13, 2009 | 05:30 PM
Deception's Avatar
Where should it go to?
prosports - i got them from a local metro guy, they worked on his car
lemme run out and take a pic so you can see
Old Aug 13, 2009 | 05:52 PM
Deception's Avatar
BOV T'd into intake mani
another view of BOV connection
BOV
wastegate connection to intake mani
WASTEGATE - line runs off the bottom barb, there was a top & bottom barb, but they took off the top one
MAP SENSOR
Old Aug 13, 2009 | 06:02 PM
Soul Coughing's Avatar
what does the map sensor say on your logs?
Old Aug 13, 2009 | 06:23 PM
Deception's Avatar
im gonna have to borrow my sisters laptop and download them
Old Aug 13, 2009 | 06:33 PM
sohc_mshue's Avatar
lol i doubt our are getting 19psi when you aren't even trying to put the engine under load. What kind of boost gauge?
Old Aug 13, 2009 | 08:45 PM
Deception's Avatar
[QUOTE=sohc_mshue,Aug 13 2009, 09:33 PM] lol i doubt our are getting 19psi when you aren't even trying to put the engine under load.
Old Aug 13, 2009 | 09:12 PM
Joe @ Tempest's Avatar
yea not going to go to 19psi crusing. not to mention you ever went from 8psi to 19psi....you would be able to tell. either it would become REALLY fun.....or you would drive over your pistons and rods after they fall out of the block if your not tuned/have the parts to do so lol
s2konroids
Aug 19, 2014 06:45 AM
SilverstonedAP2
Mar 27, 2012 06:31 PM
jwa4378
Nov 19, 2008 05:50 PM
Kenpo_S2000
Aug 16, 2006 03:37 PM
ideugene
Aug 11, 2005 09:55 AM
