Turbo Oil Restrictor
Having a oil leak with my turbo setup. I thought it was the Turbo drain causing the issue and tapped the girdle. Unfortunately, it still seems to have a very small leak. Not sure if the turbo seal is completely gone but it was rebuilt around 1 year ago.
I was thinking of putting a smaller restrictor to see if that would do the trick. The restrictor size I have now is .040 I believe. I know they make a .035 size but couldnt find anything smaller online. Does anyone know if there is a smaller size to try?
Thanks
Thanks
Originally I was getting a lot of smoke out of the exhaust. One was the PCV Valve and the other issue was the location of the drain. I corrected the PCV issue and it helped when WOT but there was still smoke. Now with the new drain, there is stilla bit of smoke. Seems like everything I do to correct it helps a bit but doesnt eliminate it.
Also my intake pipe/filter when removed has oil residue eventhough I cleaned it after the new turbo drain was put in. When the car is idle, there is a small amount of oil leaking to the floor from the turbo but cant see exactly where its coming from. I might just jack it up this weekend and let the car run to determine what is exactly leaking.
Tobisenpai
Oct 3, 2012 09:29 AM
#1turbos2k
Dec 26, 2010 04:46 PM
