Turbo water cooling.
Originally Posted by itlynstalyn,Nov 1 2010, 12:32 PM
Not even remotely correct. I've ran my GT3071R without the water lines for the entire time it's been on my car (5k plus miles). The water lines per Garrett are there to cool the turbo as the car is cooling down to prevent the oil from coking around the seals.
Per their website:
You can run the turbo without the water lines no problem, as many have and do. Just remember to let your turbo cool down before turning the car off.
Per their website:
I'm still learning the ins and out's of turbo's had always ran SC's in the past. Turbo's are SOOO much better though
Originally Posted by spectacle,Nov 1 2010, 01:11 PM
My water lines are running from the throttle body coolant lines. Haven't had an issues that I know of. My stock oil cooler is still in place with the Mase kit
Per their website:
Per their website:
Also from their website:
Garrett ball bearing turbochargers require less oil than journal bearing turbos. Therefore an oil inlet restrictor is recommended if you have oil pressure over about 60 psig. The oil outlet should be plumbed to the oil pan above the oil level (for wet sump systems). Since the oil drain is gravity fed, it is important that the oil outlet points downward, and that the drain tube does not become horizontal or go “uphill” at any point.
Following a hot shutdown of a turbocharger, heat soak begins. This means that the heat in the head, exhaust manifold, and turbine housing finds it way to the turbo’s center housing, raising its temperature. These extreme temperatures in the center housing can result in oil coking.
To minimize the effects of heat soak-back, water-cooled center housings were introduced. These use coolant from the engine to act as a heat sink after engine shutdown, preventing the oil from coking. The water lines utilize a thermal siphon effect to reduce the peak heat soak-back temperature after engine shut down. The layout of the pipes should minimize peaks and troughs with the (cool) water inlet on the low side. To help this along, it is advantageous to tilt the turbocharger about 25° about the axis of shaft rotation.
Many Garrett turbos are water-cooled for enhanced durability.
http://www.turbobygarrett.com/turbobygarre...bo_tech101.html
So, the water cooling is a passive solution to prevent oil coking instead of having a turbo timer keep the motor idling after shutoff. (Or just driving gently for a bit before shutting down.)
Originally Posted by jwa4378,Dec 1 2008, 10:42 AM
I am probably going to get a Bosch water pump, and run a closed coolant loop from the lower radiator hose supply, through the turbo, returning to the top radiator hose.
Try CSR or was it RCS pump expensive but way better then the bosh pump
If it was me I would do two turbo timers one to run the car for 5 min for first cool down then a second that runs once the motor is off to keep the water pump running for another 5 min.
In addition to that would have a reservoir in the feed system to increase the hot flow (thermal flow) effect even after all the turbo timers are shut off.
[QUOTE=Torque Obsessed,Nov 1 2010, 03:57 PM] Also from their website:
Silver S2k4
Feb 21, 2008 01:14 PM
