Twin-Volute Turbos Coming???
Old Nov 19, 2018 | 03:35 PM
DavidNJ's Avatar
Default Twin-Volute Turbos Coming???
If you've seen the press release for the new 4-cylinder Silverado, it has a 2.7L turbo with a new BW turbo. It also has a very VTEC-like twin-lobe cam that apparently is on some other GM vehicles.
Anyway, the twin volute is supposed to spool significantly better than a twin scroll. No aftermarket turbos yet, but the current BW line including the EFR has been around for a while and Garrett now has the G-series in both G25 and G42 sizes. Maybe 2019 SEMA?
This is a pic, a press release, and a 2009 SAE paper. The paper also talks about a version with VTG. Surprisingly, the version GM is using does not have VTG. Given that the GM engine has an electric water pump and electronically controls water flow to block, head, and turbo/exhaust manifold and a processor-controlled oil pump that does the same for bearings, turbo, valvetrain, and oil squirters (computer-controlled piston oil squirters?).
https://www.borgwarner.com/newsroom/...soline-engines
https://www.sae.org/news/2018/09/bor...e-turbo-design
https://www.sae.org/news/2018/05/gm-2.7-l-i-4-revealed
http://www.turbos.bwauto.com/tools/download.aspx?t=document&r=530&d=623
Old Nov 19, 2018 | 03:42 PM
Euro_Ricer's Avatar
Ford is also playing with turbo technology. They are using an electric motor to instantly spool - no lag.
Old Nov 19, 2018 | 05:12 PM
spdracerut's Avatar
Interesting. This twin-volute design has been used for a while in diesel.
E-turbo has been used in Formula 1 since 2014. Should see it on cars you can buy in a year or two.
Old Nov 19, 2018 | 05:22 PM
F1TwoThousand's Avatar
Biggest benefit i see is more 'reliablity'. The twinscroll design as i see it merges the two separated exhaust banks into the turbing wheel through an inside and outside lane if you will. The new design feeds the turbine on two inside lanes via an inside lane and an underground subway lane underneath it. Basically applying two forces on the inside of a bearing vs applying the same force on the inside AND outside will give better bearing life and can make the turbine housing amd wheel slimmer. Think of using wheel spacers and how they affect bearing life the further they are from the hub, same thing with the distance exhaust flow hits from a turbine, the closer you can get it to the bearing the better. Atleast thats my take at a glance but i am no expert at all.
MB
Mar 22, 2011 09:19 AM
DFWs2k
May 19, 2010 08:06 AM
gilby1kanobie
Feb 17, 2010 10:54 AM
BlackS2000Turbo
Jul 12, 2005 03:51 AM
