Two BOVs...special way to run vacuum line?
I am thinking about have a BOV installed on both my hot and cold charge pipe. I am curious to know if the two BOVs need to be hooked-up in a "special" way, or if I simply run a vacuum line from each to the IM?
Originally Posted by JDM S2000,Mar 30 2007, 02:34 PM
that would be sweet, but no, just needs a good vaccum source
Originally Posted by timg,Mar 30 2007, 05:47 PM
For 99% of the S2000 setups, it will just be bling. Unless you're running a HUGE turbo with a small BOV at high boost pressures, it's not necessary.
Tim
Tim
You are right. I am going for something a little different.
Justin
