vac lines from wategate?
Old Jun 12, 2005 | 05:07 PM
lexar13's Avatar
Default vac lines from wategate?
i am installing my custom turbo kit right now and i need to know where the two vacume lines run from my tial wategate. their is a flange on top and toward the bottom that im would assume both take vacume lines so i need to know where to run them..thanks
Old Jun 12, 2005 | 06:30 PM
hmss2000's Avatar
i believe the top nipple of your wastegate is only if you are running a boost controller and the nipple on the side of the wastegate gets teed in to a vacum source(vacum line from the manifold to the fuel pressure regulator). guys correct me if im wrong, just trying to help.
Old Jun 12, 2005 | 08:52 PM
timg's Avatar
If you're running a boost controller, follow the directions that came with it (there are many different correct ways to run vacuum lines). If not, run one to the bottom of the wastegate and leave the top open to air.
Tim
Old Jun 13, 2005 | 06:56 AM
lexar13's Avatar
awsome thanks!!!
lude92_si
May 17, 2016 01:49 PM
FurY
Jul 10, 2007 11:08 AM
macprotege5
Apr 10, 2007 12:25 AM
2QYK4U
Mar 31, 2007 06:39 AM
lexar13
May 26, 2005 10:39 AM
