The Ultimate GReddy Turbo Kit Thread
Im boosted! Yay
Anyone else have trouble with the Filter re-locator leaking? I have what sees to be the lower AN fitting on the engine side leaking... No matter how tight I get it. Thinking I may pull it back off tomorrow and re-teflon the side that installs to the flange?
Got pissed and started punching it... kidding... No I noticed the Pipe plug (Faces the WG when installed) was slightly protruding. After much fighting I go to it with an alan and tightened it up some... Looks like the leak stopped but not sure...
New problem, anyone else have a problem with the Greddy DP being too short? My Flange is maybe a 1/4" from the tranny and when the spring bolt is installed the DP still dosent seal to my test pipe.. and the bolt rests against the tranny and rattles like a bish. Ill try and get a pic next time I have the car up.
IS there a solution or will I need to have my downpipe extended? Also considered getting a 3 bolt flange and using it as a spacer after the test pipe but cant find one with that pattern (Hondas are offset???)
HALP! Leaky exhaust sounds like POO
Im boosted! Yay
Make sure the oil filter block adapter is tightened against the block good enough, a lot of people don't tighten it good enough and blame it on the adapter.
Originally Posted by TheChazz' timestamp='1314515844' post='20920898
Im boosted! Yay
Anyone else have trouble with the Filter re-locator leaking? I have what sees to be the lower AN fitting on the engine side leaking... No matter how tight I get it. Thinking I may pull it back off tomorrow and re-Teflon the side that installs to the flange?
Yup got that, Actually ensured the plugs are teflon'ed and the AN fittings both just got brand new seals... In the quest to stop the leak I managed to shred a seal by over-tightening (&&#@&*$*!!!) So Ill try and pick up another tomorrow. As for the plate to block seal... After watching from the bottom I am sure its from the AN fitting, Just still cant tell if its the Oring side or AN side...
I bought the car about a month ago and am having problems left and right. The latest...the check engine light came on and said I was running lean. It turned off after a day, and seemed fine. A couple days later it started sputtering down the highway and just died. Wouldn't turn over. I took it to a shop, and the following day when they went to look at it, they said it started and ran fine. I and they have no idea what's wrong. Possible fuel filter clog? Something wrong with the emanage? Has anyone ever had this happen?
I'm honestly just thinking about converting back to stock and selling the kit. With it having upgraded injectors would I need stock ones again? Would everything be ok ECU-wise if I remove the emanage, or does the emanage change things automatically?
