UR turbo kit installed boost at over 14psi?problem
Old Aug 10, 2007 | 09:46 AM
billybobxxx's Avatar
Default UR turbo kit installed boost at over 14psi?problem
hi,
i bought a used ultimate-racing turbo kit and just finish install it on my 2004 S2000 last week. my problem is that the boost goes over 14psi...but the ultimate-racing kit is supposed to boost at 8psi.
i have suspect the tial 38mm wastegate springs, but after verifivation it's the good one, the springs in the wastegate is a small blue 1.87'' diameter.
why the car boost at over 14psi when i have a 8psi wastegate spring?? the vacuum line on the top mount of the wastegate goes into the turbo??
14psi not very good for a stock engine with OEM headgasket!
thanks
ps sorry for my english
Old Aug 10, 2007 | 09:48 AM
afwfjustin's Avatar
Yikes - you need to stop driving your car hard because you could definitely cause damage with spikes like that.
Are you using any kind of boost controller? What kind of management are you running?
Old Aug 10, 2007 | 09:54 AM
no boost controller and i have a blue greddy emanage. UR racing kit doesn't come with a boost controller so i dont think i need one.
my greddy emanage is not yet tuned my appointment at tuner shop is august 20. but you cannot control the boost with the emanage?
would i have to suspect emanage map??
thanks
Old Aug 10, 2007 | 10:09 AM
PeanutButter's Avatar
Vacuum line goes to the side port not to the top
Old Aug 10, 2007 | 10:19 AM
the wastegate have only one line to plug a vacuum hose, so i guess it's ok, but this line goes where? to the turbo?
Old Aug 10, 2007 | 10:28 AM
ok just check i have two port on the wastegate, one on top and the other on the side.
the top goes to the turbo? or the side port goes to the turbo?
thanks for your help
Old Aug 10, 2007 | 11:37 AM
ok i found my problem...the top port connection of the wastegate goes to the atmosphere. it was connected to the turbo, it's why i have the double amount of boost...i just disconnet this hose and everything is fine now the turbo dont go over 8psi.
I suppose this hose is where we can plug an adjustable boost controller if we want more boost over the 8psi springs
thanks
Old Aug 10, 2007 | 11:47 AM
AirborneS2K's Avatar
Wow.
This is why you do your homework before getting into F/I on a car that comes N/A stock.
I'm glad you solved your problem before anything serious happened to your motor.
Old Aug 12, 2007 | 11:35 AM
ChefJ's Avatar
Yea. 14psi on an untuned completely stock motor can be disasterous.
nightowl
Mar 2, 2011 07:51 PM
g352s2k
Sep 6, 2009 04:27 PM
JuicedS2K
Jul 9, 2009 05:47 AM
nappymike
Mar 11, 2009 02:34 PM
