vortech belt tentioner
Old Jun 9, 2005 | 09:14 PM
Y2KS2000's Avatar
Default vortech belt tentioner
mine keep coming loose. anyone have the same symptoms?
Old Jun 9, 2005 | 09:28 PM
Slows2k's Avatar
You need to make sure that you are tightening the lock nut all the way. It's in a flaming pain in the ass location, which makes it difficult to get a wrench on. A thin wall "tappet" wrench works well to tighten the lock nut.
Old Jun 10, 2005 | 04:32 AM
xviper's Avatar
https://www.s2ki.com/forums/index.php?showtopic=115118
Old Jun 10, 2005 | 11:22 AM
mhollifi's Avatar
My belt was loose three days ago just after a dealer install of the new MAP sensor. I am so cynical that I first thought that maybe they had loosened it. The SC has been on for over 2 years and 16,000 miles and this is the first time the belt has been loose. After tightening it up, I took it for a test run and after about 10 miles returned to find it loose once again. Retightened it the next day and now all seems well.
Old Jun 10, 2005 | 12:36 PM
RZFD's Avatar
Some blue loc-tite might help, keeps things in place. I used some on my intake manifold after installing my Spoon ventuli plate becasue the bolts would vibrate loose and cause a vacuum leak.
Old Jun 10, 2005 | 02:06 PM
Slows2k's Avatar
[QUOTE=mhollifi,Jun 10 2005, 02:22 PM] My belt was loose three days ago just after a dealer install of the new MAP sensor.
Old Jun 10, 2005 | 02:54 PM
Y2KS2000's Avatar
Originally Posted by Slows2k,Jun 10 2005, 02:06 PM
A dealer tech has better things to do than crawl under your car and loosen a PITA tensioner for no reason My $$ is on them joyriding the car before you got it back.
thats why i dont take my car to any shop. i didnt know that the jamb nut needed to be tightened all the way. i going to try that this weekend.thanks.
Old Jun 14, 2005 | 04:15 AM
Venomous S's Avatar
if thats the case that you didn't tighten it all the way I hope you didnt score the plate behind it
Old Jun 14, 2005 | 06:46 AM
xviper's Avatar
Or weaken the threads on the adjuster. Without the jam locknut done up fully, some or all of the belt tension is held by the adjuster. That's not what it's there for.
lexar13
Dec 14, 2005 04:27 AM
lexar13
Nov 16, 2005 02:25 PM
Anthonymv
Oct 3, 2004 10:02 AM
CarbonFiberLip
Oct 9, 2003 01:01 PM
