vortech running rich part throttle.
so ive just installed a vortech supercharger running 7psi with aftercooler. ive got the comptech fpr instead of the vortech fpr. at part throttle in third gear the afr is 10.5. i know this is waay too rich for part throttle. is this normal? ive adjusted the comptech fpr the best i can. runs high 12 afr in the top end.
Vortech runs lean out of the box a lot. You probably have it almost maxed out seeing as you're still running really lean up top but really rich partial throttle. Should get into the 11's afr up top.
Before I was tuned my vortech would be running in the 14's up top. Just couldn't supply enough fuel at all.
Once tuned its been perfect ever since.
JohnChan
Dec 10, 2003 05:47 AM
