Vortech units that run lean
So it looks like this has the same effect as the recalibration kit?
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
What your doing is adding pre load to the spring. The Comptech fpr has an adjustment bolt on top that compresses the spring down as you screw it in to achive the same thing. Or you can replace the spring with a stiffer one for more tension this way.
I didnt realize the Vortech FMU wasnt adjustable.
Also FYi -I just found after talking to CT Engineering that the Ap2 FPR from Comptech has not only a stiffer spring but a larger piston on the bottom portion of the fpr for a quicker ramp up of fuel delivery with the f22, thought this would be good info for anyone that is considering purchasing a CT FPR. I'm actually looking for a used Ap2 fpr for myself if anyone has one for sale?
johninator
Jan 31, 2005 07:49 PM
