Vortech V2 2.87" Pulley
Old Sep 15, 2014 | 07:32 PM
donaldmejr's Avatar
Were all the pulleys made by ASP?
Sent from my iPhone using Tapatalk
Old Sep 15, 2014 | 07:45 PM
99SH's Avatar
^ Yes
Old Sep 15, 2014 | 08:02 PM
donaldmejr's Avatar
Ok thanks man...I think I'm going to have them make me a 6.0" with a 10 rib. I take it you had to make spacers for the blower bracket?
Old Sep 15, 2014 | 08:27 PM
99SH's Avatar
^ Yes space it out based on # of ribs, so in this case 3.56 mm / rib * 4 ribs = 35.6mm spacer (ASP will make spacers for you too).
Some more notes on running a 10-rib:
  • The 6" 10-rib crank pulley may likely not fit as it'll interfere with the power-steering steering bolt.
  • Note the offset water pump pulley I had made as well for additional margin. Without having an offset face, the belt will come close, but is probably OK.
  • I had to get 10mm steering spacers (e.g. bump steer spacer) to move the rack up some to clear the pulley.
  • You'll need a new idler pulley as well to match the 10-rib pulley. Make sure you account for the offsets and such on the idler considering it'll be wider
  • Need to purchase a longer oil feed line for the blower. The stock SOS line happens to work, but you won't have any strain relief.
  • You'll also need to notch the cross-frame member right under the blower as the oil return port will interfere. You'll need a 90-deg elbow to clear to route it out
  • Before choosing any pulley combo, check to make sure a belt of proper length is available. The 10-rib belts dont come in incremental size options like the 6 or 8 rib do. It's very very limited.
PM me for more info, I don't want to take this thread off topic for the OP. In a nutshell, I would probably recommend going with a 8-rib as it's easier to work with.
more pics here: https://www.s2ki.com/s2000/topic/103...y-setup-wpics/
APoner
Jan 30, 2022 12:55 AM
grantedS2k
Jan 10, 2007 11:52 PM
club1320
Jan 4, 2007 10:21 AM
johninator
Sep 17, 2005 03:03 PM
dave22
Jan 24, 2005 06:53 AM
