Vortech V2 loose boost... Heat soak?
Myflys2k, thanks for you post, I have a hope again, that my boost less -depend from intake air to airfilter!
Have any one -boost leak from injectors ( injector seal on intake manifold? )
Mine 3 injectors holes in intake manifold has wet spots around)
Boost test which i wrote, was by launch smoke to intake from airfilter inlet tube, on off switch engine, with closed throttle .
May be injectors seals on intake manifold skip intake air under WOT, (loose boost) ?
Check this out: https://www.s2ki.com/s2000/topic/874...#entry22398086
I have oil spots under valve cover+oil-depth gage+camshaft position sensor...
i heard on s2ki forum pages about a problems with PCV valve in S/C s2k , in what it is expressed !?
how I can check the boost productivity of the my charger !? (to understand boost leak or or bad boost productivity of charger i have)
I see on hondata data logs, 4.5 psi max, от 9000rpm in ambient "-10F"
and IAT - near "-4F"
blink962
May 23, 2013 10:46 AM
Moddiction
Oct 14, 2012 08:43 AM
Wydget
Dec 23, 2011 01:53 PM
