WARNING TO AEM WATER/METH GUYS
the aem kit should have a pressure sensor on the pump you could use to do the same thing.. im not 100% sure on that
http://www.google.com/products?rlz=1C1CHMI...=title&resnum=4
Looks like the AEM doesn't have a pressure switch, only fluid level and electrical error detection. The Aquamist has a pressure sensor (not a flow sensor) to detect low pressure on the output side, which will also indicate incorrect flow.
The actual pressure sensor is a transducer, probably a Fujikara or Motorola, and they are only ~$18, but you have to design/build the circuit to run it
You can buy more packaged pressure sensors from Omega.com for $36 but you have to know how to design it in
Another way is to use a small diameter thermocouple that is in the intake tract. It has a very fast response time. Then you can attach it to a TC amplifier IC and ultimately cut boost if the intake air charge is not less than what you should be seeing from the meth injection - this is what I got.
Aquamist FTW, plus you get the kickass 200 PSI solenoid type pump with it.
Sorry for the excess babble
Originally Posted by SFV_S2k,Aug 1 2009, 08:29 PM
I started do look into that but no one seems to have any info or even know what I was talking about
Ill let u know if I find anything...
I even set it up to work with a switch but the ems didnt seem to wanto work
X2
X2
Originally Posted by THESPY,Aug 2 2009, 10:07 AM
Couldn't you use the "nitrous" map for meth and the reg one for pump. I think its AEM EMS that has that switch.
The extra fuel and ignition are set in to the noz setting, so in theory when i turn off the noz from the ems ill run my normal street map( no meth).
But for some reason my ems isnt responding. I can turn it on and off when its connected to my labtop but not when i manually do it from the dash switch.
Yes. the AEM unit has a line that switches with the spray. I feel the best safety is a pressure switch hooked to the wastegate solenoid. It should sense the pump voltage and pull the gate open if there isn't pressure.
Joey: The sureflow pump is an off the shelf irrigation pump if you happen to need a replacement. They're cheap at around $60. Sorry about your top. I've been there too. Takes it out of you.
no one here try to use those kits ??
http://www.labontemotorsports.com/store/cc...ne+Systems.html
it looks very good and have all kind of safety features
http://www.labontemotorsports.com/store/cc...Monitoring.html
