What Caused It?
Old Jan 24, 2006 | 10:55 AM
  #21
RED MX5's Avatar
Originally Posted by GOGOGO,Jan 24 2006, 10:27 AM
One more thought, I noticed that you seemed to be pumping a ton of raw fuel out the exhuast at the Dragon last year, and the trip back. Hence the flames, and backfiring. So what I think could be happening is fuel washout. To much unburned fuel can wash the oil away from the rings, and cylinder wall, that you would pick up scarring. Just washing out the same spot over and over with no lubrication???? What you guys think?
Mark
I'm certainly no expert, but that's exactly what I'm suggesting (as a possibility). I believe that the #4 cyl runs a little leaner than the other three, and #2 might run slightly richer. If the car was blowing fireballs and smoke from unburned fuel then I have a hard time believing that it was running lean, and I believe that these precursors DO point to a rich condition that might wash the lubrication off the cylinder wall in #2. A plugged or restricted oil jet or banjo bolt could also be a contributing factor.
Of course it could be totally unrelated to the rich running or the oil jets; I'm just guessing. The damage is right between the intake valves, in an area that is probably getting a good shot of fuel, which comes out of the injector and is spread out by the valve head. I think the damage is right in the area where there is a shot of fuel hitting the cylinder wall, and if there was a lot of raw fuel there it would certainly wash out the lubrication, as well as making the car smoke and blow fireballs. Maybe I'm way off base here, but there sure is a lot pointing to both lubrication failure and an overly rich condition.
Old Jan 25, 2006 | 04:15 AM
  #22
jbotstein1's Avatar
No flames please... I have no idea, just applying knowledge I acquired here on s2ki.
Is it possible that the head was lifting causing the piston to wobble and score the cylinder? Or would that be a uniform scoring across all cylinders?
Old Jan 25, 2006 | 04:25 AM
  #23
blues2k3's Avatar
Usually I would side on the fuel washing if there was visible signs of the car running excessively rich. However, you should have seen consistency throughout other cylinders. Which then leads to other suggestions such as excessive slap or improper oiling from the oil jet.
Russ_3D
Oct 5, 2017 05:13 PM
hockeylfe11
Apr 22, 2015 03:46 PM
s2k.igor
Nov 18, 2010 09:16 AM
Drkphnx
Sep 27, 2007 05:38 AM
bgbfflochp
Apr 16, 2004 12:30 AM
