What do I need to run 9 psi?
Old Jan 9, 2006 | 12:56 PM
my01s2k's Avatar
Do you need to upgrade the bottom ends (differential) for the 9lbs boost? or will the stock rear end can handle the boosts?
Old Jan 9, 2006 | 01:21 PM
John_Z's Avatar
Stock rearend is fine as long as you don't dump the clutch too often.
Old Jan 9, 2006 | 01:31 PM
C4SxM5's Avatar
you can also check on ebay. i found mine used through a member here.
Old Jan 12, 2006 | 08:12 AM
my01s2k's Avatar
is 550cc rc injectors sufficent enough handle the 9lbs boost? or is it better just to go with the 650 cc?
Old Jan 12, 2006 | 08:14 AM
Black Nugget's Avatar
Personally I would go with 650cc injectors - in my opinion it is better to have extra than not enough.
On my last tune with the 3.25" Pulley my tuner saw 9.75psi - he said due to weather conditions I should see another 1-1.5psi under cooler conditions. With a fuel pressure setting at 57psi he said that if I gained that extra 1psi I would have been around 84% duty cycle on the 650cc's. So I honestly think 550's would be too small for 9psi.
Again, this is just my opinion - hopefully a tuner can confirm/deny this!
Old Jan 12, 2006 | 08:16 AM
I have an 00' with 78k miles - 4k of which were on a Tech2 7psi Pulley, 2k were on a 9.75psi Pulley. No launching the car, but many many hard gear changes. When we took my differential apart not too long ago everything looked fine - however my axles weren't in the same condition, they went bad.
Non-the-less, I still chose to send out my differential internals to www.percryo.com (Performance Cryogenics) for cryo-treatment!
Bibbs
Feb 24, 2007 11:05 AM
gusrock77
Aug 9, 2006 12:52 PM
Titounais
May 15, 2006 02:18 PM
Nick32
Mar 3, 2006 09:38 AM
SC-S2000
Feb 20, 2006 10:02 PM
