what to expect
Old Oct 3, 2006 | 09:45 AM
passmans2kny's Avatar
Default what to expect
full race stage 2 gt kit, gt3037r with a inline pro 3mm headgasket and arp studs and bolts, what can i expect on say 15 psi? i was guessing low 400s
Old Oct 3, 2006 | 09:56 AM
CaptKirk's Avatar
Sounds about right IMO.
If I was to upgrade my exhuast and raise my boost on my setup to 15 psi, I should be right around 400. So with your "more efficient" full race manifold, I'd say that low 400s sounds about right.
Wait you're getting a GT30. I have a GT35... so i dunno the difference in cfms that these two flow... so I dunno. I guess very high 300s to low 400s should still be a safe bet.
Old Oct 3, 2006 | 10:01 AM
im not so sure i should have went gt30r, but if that turbo is good to 500 hp like full race claims then i wont care about not getting the 35r
Old Oct 3, 2006 | 10:08 AM
CaptKirk's Avatar
From what I've read and gathered, the GT30 is good up to mid 400s. I dunno if the full-race manifold can make it efficient enough to be good for another roughly 50 whp, but i wouldn't be surprised. Unless you're trying to crack the 500 whp mark, you should be fine.
Old Oct 3, 2006 | 10:50 AM
WtbS2k's Avatar
I would go with a GT35R if i am going with the 3mm gasket. There's always room for upgrade when you need more power with this turbo.
Old Oct 3, 2006 | 02:15 PM
John_Z's Avatar
Probably around 400whp. Did you ask Full Race what they thought?
Old Oct 3, 2006 | 02:58 PM
XclusiveAutosports's Avatar
I would rather have the quicker spool up with the 30R and upgrade down the line to the 35R if I ever wanted to go past 450whp. I can't imagine needing more power then that, but I guess you always want more.
Old Oct 3, 2006 | 03:23 PM
full race claimed it was good up to 500 hp, i think ill be fine anywhere over 400
Old Oct 3, 2006 | 04:04 PM
mys2k3's Avatar
Didn't "wannabuy" pull around 450hp with the 35r at around 13-14 psi?
na2king
Dec 21, 2014 04:55 AM
donaldmejr
Mar 24, 2012 09:38 PM
japancrx90
Mar 21, 2011 09:24 PM
stantaur
Apr 19, 2008 03:24 PM
dshen921
Jan 4, 2008 07:52 AM
