What will it take to run E85?
A single walbro and ID1000's will get your roughly 450whp on E85 and if you add a Bosch inline pump and up the fuel pressure to around 90-100 you can get 580-600whp with E85. If you aren't using an efficient manifold then you might wanna shift these estimates to the left.
Another note - if you are only running a log manifold then it wouldn't be worth running E85 for an extra 30-50whp depending on your setup. Stock HG/log manifold with 93 pump can achieve around 400whp and E85 - 450whp. Add that bosch with E85 and maybe low to mid 500? I've done a little testing with the many setups I used.
Anyways, sounds like I'm right on track then for 450 on E85. Hopefully the Walbro and ID1000s will be enough. If not, I'll upgrade to a 340lph pump and that should get me there.
Plus its nice to not have to worry as much about it cracking at this point.
Build for your review:
This one is a Fullblown Stage 1 log mani
https://www.s2ki.com/s2000/topic/860...#entry20493031
I would just get the fullblown fuel pump anyway for a few reasons. It will easily handle the flow you need without maxing out the walbro. It is very quiet!! I do not even know pump is running when you turn the ignition on. No more walbro whine. That in itself is worth the cost IMO.
