what's better
Old Aug 3, 2005 | 12:38 PM
jal3lee's Avatar
Default what's better
What is better, turbo or s/c? i've heard turbo because it can be upgraded (i assume meaning stage1, stage 2 set ups). but i thought i read that s/c is safer and gives you a longer engine life.. true? what kind of gain is had with each sytem (hp/tq)? will you get that low end power that s2k might lack?
Old Aug 3, 2005 | 01:45 PM
S2000RAT's Avatar
If you want over 400 WHP go with a turbo. If not then SC it.
You will need a good tuner for a turbo setup.
Rich
Old Aug 3, 2005 | 02:42 PM
xviper's Avatar
Look at the FAQs at the top of this forum. It'll have links to threads that have discussed this.
Old Aug 4, 2005 | 07:06 AM
jareds2k's Avatar
go turbo
Old Aug 4, 2005 | 08:58 AM
RZFD's Avatar
If you want torque the S/C isn't going to cut it.
If you want more than 300HP you might as well go turbo becasue you're going to spend just as much on injectors, EMS, ect to get there.
Reliability is only going to be as good as the tune and equipment, an off the shelf S/C doesn't really require any but once you start trying to upgrade that kinda goes out the window.
I'd figure out exactly waht I want and talk to a reputable shop about getting there. If you have to ask then you probably shouldn't undertake either on your own.
GyozA
Oct 31, 2006 05:16 AM
j_c_a
Oct 14, 2005 06:28 AM
JohnyNy
Mar 30, 2005 07:58 PM
AndyDoh
Aug 20, 2003 07:28 AM
S2K_Ownz
Oct 30, 2002 06:12 PM
