where can I buy a higher compression pulley
Old Mar 15, 2007 | 08:38 PM
Titounais's Avatar
Default where can I buy a higher compression pulley
Hi I will install a comptech sc on my s2k and I want to get a higher compression pulley. I want to know If I go to 7 or 9 psi if I leave everything else stock it would cause a problem? I think the stock comptech pullley pulls 5 psi? I also want to know the cost of a pulley and where to buy it.
Thank you
Old Mar 15, 2007 | 08:57 PM
Dsgs2k3's Avatar
7 psi u dont have to do much except get it tuned. 9 psi u are gonna need to get engine management, bigger injectors. get the pulley at automotivespeed.com
Old Mar 15, 2007 | 09:58 PM
73Zero's Avatar
Here you go: http://automotivespeed.com/product_i...roducts_id=251
Old Mar 15, 2007 | 11:13 PM
faukengenius's Avatar
so with the 9lb, if i have the 750cc injectors and aem ems a little tuning I should be good with the stock block?
Old Mar 16, 2007 | 02:32 AM
EriS2k's Avatar
10psi pulley at Science of speed.com
12 and 14psi pulley need to all ASP Racing
Old Mar 16, 2007 | 06:01 PM
ATOice's Avatar
I have a 7 lb pulley, took it off to do my upgrade.
Old Mar 16, 2007 | 06:08 PM
gomarlins3's Avatar
Originally Posted by 73Zero' date='Mar 15 2007, 10:58 PM
That was going to be my suggestion as well.
Old Mar 17, 2007 | 11:28 AM
bimmerpowa's Avatar
So can you run a 7 psi pulley with stock injectors and a stock ECU comfortably?
Also, one more question, the Comptech S/C comes with a 6 psi pulley correct?
TheBigShow
Sep 2, 2009 08:11 AM
jdmdohcpower
May 18, 2009 12:28 PM
j66
Sep 23, 2006 04:48 AM
Nick32
Apr 17, 2006 04:29 AM
LonS2k
Sep 25, 2005 12:48 AM
