Where is everyone at with their
Old Oct 3, 2010 | 08:01 AM
  #31
Suzuka_Joe's Avatar
Installed spoon calipers and 10mm spacers. Realized i need 11mm to clear. I need a 3mm spacer now
Old Oct 3, 2010 | 08:14 AM
  #32
metros's Avatar
Congrats spectacle! Just moved into my first home a few weeks back.
Old Oct 3, 2010 | 08:16 AM
  #33
B5254T4's Avatar
I´m buying parts right now and wait for the last Mase parts to arrive.
Holset HX40, Tial WG, ID 1000´s, AEM v2, AEM FPR, SteedSpeed manifold (ported), custom 3" exhaust, fuel system and IC.
Will post a project thread when I start, got a dyno at my job and hope to finish fast.
Old Oct 3, 2010 | 09:42 AM
  #34
JawKnee's Avatar
Nothing too exciting on my end.
After I installed my SOS Base kit on my '05 7+ weeks ago, my clutch started to slip.
I dropped off the car to have the SOS sport clutch kit and ap1 flywheel installed today.
Nothing major like most here, but I'm pretty excited to no longer have a slipping clutch, not to mention a lighter flywheel. I'll finally able to dyno it as well.
Old Oct 3, 2010 | 11:45 AM
  #35
metros's Avatar
Finished swapping all the sensors on the kpro. Installed the new valve cover and all fittings. Ran harness through the firewall, installed hondata ecu.
Things left:
- Reinstall all pulleys and belt
-Add extra ground from valve cover to body
-Double check everything
-Add Oil/coolant
-Install basemap
-Cross fingers and turn key
Is it possible to start the car without the accessory belt/pulleys on the front of the engine? I want to make sure everything is working properly before I button everything up.
Old Oct 3, 2010 | 01:44 PM
  #36
vduber's Avatar
metros arent you getting a ptuning kit? did they send you a base map or did your tuner, im just curious cause i may get one and i never heard of a base map coming from ptuning
Old Oct 3, 2010 | 01:54 PM
  #37
jaundice's Avatar
^^ The KPro has basemaps already loaded. They aren't great, but will start the car.
I wouldn't start the car without the belt, as the water pump won't run. Prob be ok, but just know you can't run it very long.
Old Oct 3, 2010 | 02:00 PM
  #38
vduber's Avatar
Thanks for the answer jaundice i was thinking to myself today that kpro should have to come with a base map but had no clue since ive never owned one. thanks again
Old Oct 3, 2010 | 02:21 PM
  #39
EternalLx's Avatar
It only comes with base maps for stock injectors and RC650s if I remember correctly
Old Oct 3, 2010 | 03:07 PM
  #40
metros's Avatar
I'll only be initially using the basemap to make sure I installed everything correctly and hopefully get the car to PTuning. Good point on the water pump not running, I'll just make sure the car fires up and shut it down to reinstall everything.
