wy2slow_z's Build Thread
Old Apr 8, 2013 | 04:42 PM
  #241
wy2slow_z's Avatar
shopped filters today. you CAN fit a filter on without the cooler. the problem is you wont have enough room to take the filter off without taking the mani/turbo off every time. IMO the best option is to stick with the relocation kit. my next step is to shave some off the block bolt, put in a new seal and tighten the hell out of it.
Old Apr 8, 2013 | 05:06 PM
  #242
jpetch05's Avatar
JB weld it in there
Old Apr 8, 2013 | 05:07 PM
  #243
jpetch05's Avatar
(Clearly Jk)
Old Apr 8, 2013 | 05:15 PM
  #244
wy2slow_z's Avatar
im going to put that thing on there pretty damn tight this time!
Old Apr 9, 2013 | 09:52 AM
  #245
wy2slow_z's Avatar
here is a vid of a solid pull 602@21psi, watch the first part of the second vid for the flames then skip to 5:18 to see the damage
http://www.youtube.com/watch?v=G6ZMIHeK_AI
Old Apr 9, 2013 | 06:10 PM
  #246
baZurk's Avatar
Grease Lightning works pretty well for oil clean up. That is a mess
Old Apr 9, 2013 | 06:33 PM
  #247
wy2slow_z's Avatar
thanks, i already went with the simple green. it worked pretty well. i pressure washed it first, then hit it with the simple green... rinsed, repeated a few times. picked up a new oil bolt which came shorter than the previous one (which is good). should recieve the new seal tomorrow and will start her up and make sure everything else is good.
Old Apr 10, 2013 | 01:16 PM
  #248
Corey Maurer's Avatar
Yuck. Glad I'm not the one cleaning that mess!!
Old Apr 10, 2013 | 01:43 PM
  #249
passmans2kny's Avatar
reminds me of when my trans went bulimic
Old Apr 10, 2013 | 07:18 PM
  #250
wy2slow_z's Avatar
I remember seeing pics of it. That was a mess! Got her back together and she fired right up. Little oil residue smoking from the header wrap but nothing major. Going to replace it with black wrap to match the bay a bit better. Will be a while till I can get on the dyno...tuner is busy!
