wy2slow_z's Build Thread
Old Dec 8, 2013 | 04:07 PM
  #371
herecomesboost's Avatar
Nice start Zack. Going to delete the booster as part of your tuck?
Old Dec 8, 2013 | 04:58 PM
  #372
wy2slow_z's Avatar
I have given it some thought. But like others that have gone through this... I would rather not sacrifice performance. If I knew more about it and could figure out a way to keep pedal feel and clamping force then I would! (if you have any knowledge that would be great!)
Old Dec 10, 2013 | 10:55 AM
  #373
sohc_mshue's Avatar
Originally Posted by herecomesboost
Also, you can upgrade your firmware/calibration without worrying about flex fueling (it's disabled by default anyway; won't affect your tune at all).
For now he can just log the voltage and do a math calculation in the logging software for fuel pressure. I always recommend checking the tune when upgrading firmware. There is no telling what could change...aem is known for having bugs here and there with new firmware releases. For instance when i concerted to the new firmware my o2 feedback quit working correctly. No option in the software made sense as to why this was happening and even when doing a cal comparison nothing was different. I ended up copying every table and setting from the old cal into a v2.02 firmware cal and it worked just fine.
Old Dec 10, 2013 | 11:12 AM
  #374
Interesting. Did you convert manually or use a built in script? Were you converting from 01v24 to 02v02? Sucks that you had to copy/paste lol What a headache.
Old Dec 13, 2013 | 12:13 PM
  #375
wy2slow_z's Avatar
sometime during this.... winter build i will add in the sensor and will get a retune. front mount modification and intake alone will change things.
I measured up all the lines for the ABS tuck. how onto tucking the harness a bit better and mocking up the heater control stuff in the coil area.
Old Dec 16, 2013 | 04:55 PM
  #376
wy2slow_z's Avatar
got this guy in today. pretty piece!
im pretty set on painting the block with por 15. anyone else chime in on a different product or method?
Old Dec 16, 2013 | 05:32 PM
  #377
Nice start on the crossmember. That's how I cut mine. Much easier to pry from the inside (after drilling out the spot welds). Any reason why you're leaning towards a rust protection paint? Our blocks are aluminum
Old Dec 16, 2013 | 06:04 PM
  #378
wy2slow_z's Avatar
haha thanks! seems like from what I read that the por 15 stuff will adhere a bit better to the block? I keep asking what other have done because I have no clue what is best!
Old Dec 16, 2013 | 06:11 PM
  #379
I'm sure it would stick to your block without issue. It's main function is to mitigate rust (iron oxide), which is why I was curious. What size bar are you going to use for your new crossmember?
Old Dec 16, 2013 | 06:25 PM
  #380
wy2slow_z's Avatar
the plan is to use a triangle piece that will be bolted to each side via a heavy duty countersunk flange. I just want something different. everyone seems to be putting a round pipe there. The car is scattered all over the place and I have so many directions to go to keep the build moving. Im waiting on a buddy to loan me his hoist to yank the motor out first.
oh and my hardtop is arriving tomorrow
