S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Center Console Accessory Outlet Loose
Old Apr 29, 2011 | 02:06 PM
jelanier's Avatar
Default Center Console Accessory Outlet Loose
I have a loose accessory outlet in the center console. I saw a thread where I can remove one panel, one screw and reach around to tighten it. I was hoping to see a picture of the back side of the center console so that I can see what I am reaching for..
Anyone have a picture?
Jim
Old May 18, 2011 | 03:01 AM
smohan123's Avatar
I tried doing the reacharound, but it didn't produce the expected results.
Kinky! But I still have the same problem that you do.
Old May 27, 2011 | 11:30 PM
NFR_AP2's Avatar
i used teflon tape to make the socket tight around the metal thing that holds it in place, best idea ever
Old Jun 1, 2011 | 10:14 AM
smohan123's Avatar
So instead of actually screwing it in to whatever it's supposed to screw into, you just wrapped the 12V socket itself with tape and fitted it back in the hole? That's a pretty sweet idea for a temporary fix... I should do that until I work up the courage to go back in with a screwdriver and pry off my panels again to give the real fix another go.
Old Jun 2, 2011 | 11:02 PM
newchapter's Avatar
The outlet threads into a larger piece. So essentially, what you see looking in the outlet is what's on the backside.
Old Jul 28, 2011 | 07:39 AM
insidiouseg6's Avatar
Have this problem too and my glove box key cylinder is loose ;(
TRDLiquidSilver
Nov 18, 2016 09:32 AM
Spoolpigeon
Oct 15, 2014 08:00 AM
taylorss2k
Jul 8, 2006 07:00 AM
beanolo
Apr 26, 2004 07:20 PM
Icemn2003
Feb 10, 2004 05:21 AM
