S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Nut removal behind the trunk
Old Dec 10, 2020 | 04:38 PM
mentaltam's Avatar
Default Nut removal behind the trunk
I'm having trouble removing this nut from behind the tail light, the one with the brown plastic clip over it. I used wd40, let it sit overnight, to try and loosen it but it didn't work. When I try to turn it with my wrench (very difficult to do because of lack of clearance all around) it seems like it's smoothing out the corners of the nut. The screw's too long for me to use any of my socket attachments from my drill. Anyone got any tips?
Old Dec 10, 2020 | 05:23 PM
Kyle's Avatar
Use a deep socket on a ratchet.
Old Dec 11, 2020 | 07:56 AM
engifineer's Avatar
If the wrench is rounding it you are most likely using the wrong size wrench. Be sure you have the correct size. Hard to tell the scale from the picture, but I am guessing that is a 10mm nut.
As mentioned above, use a deep well or mid deep socket on a ratchet. Do not use a drill or power tool for small stuff like this. You just risk snapping the stud off if it is bound up that way.
Old Dec 11, 2020 | 10:58 AM
Crispy808's Avatar
IIRC, those nuts are 8mm.
Old Dec 19, 2020 | 11:51 AM
rpg51's Avatar
As recommended above - do not use a drill. Do it with a ratchet an extension if needed, and a deep socket. Usually a 6 Pt. socket will avoid rounding issues.
Maybe I'm missing it - but I don't see a brown plastic clip in the picture.
Old Dec 19, 2020 | 12:58 PM
mentaltam's Avatar
Thanks for the suggestions everyone! I just had the mechanic who was replacing my exhaust (I recently bought this thing and it had a god awful after market exhaust on it that made it rattle like crazy around 3-4k rpm) and he get it lose and out in like 5 min with a vice grip wrench I think. Funny thing is that I tried getting a dealer to remove the nut while I was getting an alignment done, they rounded it off even more and then said if I wanted it off it'd be 1/2 hr labor.
And noodels, the reason you don't see the brown plastic clip is because it goes above the nut, which I took off since I was trying to remove the nut.
Old Dec 19, 2020 | 01:16 PM
noodels's Avatar
Ok but did not reply to this post
Old Dec 19, 2020 | 02:56 PM
mentaltam's Avatar
My bad noodels, I think I scrolled too much, hit another topic, saw your last reply mistaken for rpg51's comment.
Old Dec 20, 2020 | 06:52 AM
Kyle's Avatar
This whole thread gave me cancer, thanks.
Old Dec 28, 2020 | 04:34 PM
Inspired's Avatar
WD-40 was unnecessary; the bolt is not exposed to the elements. Buy metric deep well sockets and line wrenches. Remember, righty tighty, lefty loosey.
blkswan
Dec 25, 2018 01:01 AM
K_iju
Dec 13, 2018 09:56 AM
S2LEGEND
Oct 6, 2016 11:59 PM
jessiec132
Sep 22, 2015 12:33 PM
