S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Roll Hoop Compatibility?
Old Sep 19, 2017 | 06:32 AM
jts09's Avatar
Default Roll Hoop Compatibility?
I did a search, but couldn't find this info. I want to replace my driver's side roll hoop and wondered what model years are compatible with my '06?
Old Oct 1, 2017 | 08:23 AM
jts09's Avatar
I guess that there isn't a lot of info on this, or my question wasn't specific enough? The question is really two-fold. I have found that roll hoop mounted speakers were added starting in the '06 model. The second question is, did the mounting change as well? If not, I could convert to the older roll hoops and remove/re-position the speakers.
Old Oct 1, 2017 | 10:20 AM
Chuck S's Avatar
You need the "garnish" where your speakers mount or did something happen to the roll bar brackets?
-- Chuck
Old Oct 1, 2017 | 10:23 AM
Nitroturtle's Avatar
I used pre-06 hoops without speakers to replace the broken roll hoops in my '06. Had no issues mounting them, and used the money I saved (got these for a good price locally) to upgrade the rest of the stereo. I don't miss the roll hoop speakers at all.
Old Oct 19, 2017 | 06:14 AM
jts09's Avatar
The drivers side roll hoop on my '06 had been opened by a previous owner. I am looking to replace it and just wanted to know which model's had compatible hoops. I am considering using older model hoops and installing the speakers elsewhere.
Old Oct 19, 2017 | 07:55 AM
I was in the same situation. It seemed that 06+ roll hoops typically sold in the $300-350 range. I was able to pick up older roll hoops without speakers locally for ~$100 and spent the extra money upgrading the door speakers and adding an amp. I've been completely satisfied with my decision after all was said and done. I'm not sure what year the hoops I used were from, but I know they were from an AP1.
Old Oct 27, 2017 | 02:28 PM
jts09's Avatar
Thanks. That was along the line I was thinking if I can't find an '06+ hoop in good condition.
2004S2000
May 10, 2026 09:44 AM
JoePhotographer
Jul 5, 2016 11:43 AM
s2kt3
Oct 7, 2015 02:38 PM
GTS Jeff
Oct 25, 2007 04:53 AM
