Sponsored by: CARiD
AP2 LED Tail Lights
Old Dec 23, 2017 | 06:26 PM
  #21
Canadian144's Avatar
Guys, finally tossed mine on. They look great, but I had the same issue as Dman8. I'm not sure if it's just an early version issue that has been corrected?
It turns out the turn signal was just wired wrong. I just had to swap/re-solder the power and ground wires going to the connector. Easy enough fix!
Old Dec 26, 2017 | 08:54 AM
  #22
RussianHammer's Avatar
Top Answer: 1
This is what the problem is.
The Honda gray oem socket for the turrn signal reverses polarity. So you can cut and swap the positive/ negative wires on the tail light end. using quick connects makes it a quick and easy swap.
Old Jan 17, 2018 | 06:20 PM
  #23
JS2k.com's Avatar
Sponsor
If anyone just wants the LED look, JS2k.com sells Reverse Light LEDs and Turn Signal LEDs.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Feb 20, 2018 | 04:10 PM
  #24
Da New Yawka's Avatar
Anyone else purchase these and want to chime in?
Old Feb 24, 2018 | 11:47 AM
  #25
yardfog's Avatar
I'm interested too.
Old Jun 27, 2018 | 08:23 PM
  #26
DanielZan's Avatar
Yea, mee too. I got hit in rear. Replacing my AP1 tails with these.
Old Jul 10, 2018 | 12:18 PM
  #27
CMK's Avatar
CMK
Did you already receive/install them? Any thoughts? Where'd you purchase?
Old Jul 10, 2018 | 10:39 PM
  #28
DanielZan's Avatar
I should get them by Thursday
Old Jul 11, 2018 | 07:25 PM
  #29
DanielZan's Avatar
Just got them today!
They look great, but no idea how to install them. My connectors look identical to the picture below. I am technically and mechanically challenged, but these seem to not fit anywhere?
Old Jul 11, 2018 | 08:01 PM
  #30
DanielZan's Avatar
OK, ok... I have managed to fit the three conectors, except the round one. It does fit, but it does not turn on. Trying to understand the diagram suggested below to fix...
