berk header question
The only difference is that the black one is ceramic coated to reduce heat. As far as weight, probably not much of a difference between the two, but compared to the oem, the black HPC header is quite a bit lighter. I've only had mine on for about a year, with no problems.
the weight difference is quite significant between the berk and oem. i would go with the hpc coated, as you will not be able to use the stock heat shield, so i would try to keep the temps down as much as possible. i too have had mine for a while with no problems.
Urge
33
Apr 26, 2026 12:42 PM
