Sponsored by: CARiD
berk header question
Old Sep 12, 2008 | 02:22 PM
gregsju29's Avatar
Default berk header question
I'm going to pick up a berk header, I was just wondering if someone could explain the differences between the two options? Weight, heat, durability.... thanks
Old Sep 13, 2008 | 05:07 AM
gregsju29's Avatar
there are all of these people that use the header,but no one knows the difference?
Old Sep 13, 2008 | 07:43 AM
S2K 4 ME's Avatar
The only difference is that the black one is ceramic coated to reduce heat. As far as weight, probably not much of a difference between the two, but compared to the oem, the black HPC header is quite a bit lighter. I've only had mine on for about a year, with no problems.
Old Sep 13, 2008 | 11:44 AM
a_zepeda926's Avatar
the weight difference is quite significant between the berk and oem. i would go with the hpc coated, as you will not be able to use the stock heat shield, so i would try to keep the temps down as much as possible. i too have had mine for a while with no problems.
Urge
33
Apr 26, 2026 12:42 PM
Brian339
Jan 9, 2014 10:49 AM
dan_uk
Jan 23, 2011 08:08 AM
Delano5050
Jan 20, 2007 09:35 AM
HeNeSSeY
Mar 23, 2002 12:00 AM
