Sponsored by: CARiD
Front strut brace - is it worth it?
Old Feb 16, 2012 | 06:11 AM
  #21
JackS's Avatar
Might help,can't hurt and cheap enough to consider installing one on your car. A stiffer front end may have side benefits such as less prone to rattles under the hood possibly an aid in negating damage in a side impact, the slight bling factor, whats not to like?
Old Feb 16, 2012 | 06:24 AM
  #22
Moddiction's Avatar
Former Sponsor
Pretty much all bling. Especially the multi piece ones. There's a huge cross member brace already.
If you want to stiffer up the front go with a sway bar for some very noticeable improvements.
I used to have a stb looks good and nice to lean on. Noticed zero performance from it though.
Old Feb 16, 2012 | 06:26 AM
  #23
S2k007's Avatar
Originally Posted by Redline S2K
Get the Gladman performance one, it has a heatshield built on it.
I was considering this. I have an oil drain valve though. Does the heat shield block access to the valve or oil filter reaching down from the top? Any noticable effect from the head shield?
Old Feb 16, 2012 | 08:14 AM
  #24
Drkphnx's Avatar
I have a Comptech one and really don't notice too much of a difference with it on or off. I had a neuspeed one before but got the comptech one after I got the CTSC to clear it. It helps with support when working in the engine bay. I have the neuspeed for sale if ur interested
Old Feb 16, 2012 | 09:36 AM
  #25
JackS's Avatar
A tighter fit but really no problem with the fumoto or oil filter.
Old Feb 16, 2012 | 10:42 AM
  #26
ryuken's Avatar
I have a glad fab bar installed. My hardtop doesn't squeak anymore. It seems like the car rides smoother over uneven roads.
Old Feb 18, 2012 | 12:08 PM
  #27
ungucpho's Avatar
I liked my s2x strut bar. It seemed to feel better during the corners. Not bad for 200. I'm not sure if I would spend 700 on an asm bar
Old Feb 19, 2012 | 08:53 AM
  #28
TougeS2k's Avatar
If you look underneath where the strut would be, youll find a giant beam, far more chassis bracing
Old Feb 19, 2012 | 02:27 PM
  #29
zeroptzero's Avatar
The do make the engine bay look nicer, and they come in handy as arm rests when doing work in the engine bay. They might give you a bit more bracing in a front end collision, but I've never felt much of a handling difference and I've used several different bars on my ap1.
Old Feb 19, 2012 | 10:57 PM
  #30
ImagineIt's Avatar
you could always get a asm front x bracing one for like 100 bucks shipped on egray or if you want baller status just get a titanium one then your not really adding weight and getting stiffer if needed.
im sure it probably helps or dumb dumbs wouldnt add it to their expensive ass race cars unless their sponsor whoring =D
siadam
Nov 30, 2011 06:48 AM
timdon
Apr 20, 2009 08:49 AM
505sduece
Aug 16, 2006 06:41 PM
Shift_S2K
Oct 14, 2004 08:10 AM
ludeman
Feb 16, 2001 12:57 PM
