Sponsored by: CARiD
Gauges
Old Jun 11, 2013 | 06:01 AM
philipminge's Avatar
Default Gauges
Hey guys,
Just a question on gauges. I was planning on using an defi advance zd but am not sure anymore. I like the look of gauges. What gauges would people recommend. I wanted analogue style. Also would like to buy all the gear to install from the same place. I have never done this so can anyone help me with what I need exactly.
I will be installing a greddy circuit spec oil cooler also.
What do I need and where can I purchase from.
Thanks heaps guys.
Cheers
Old Jun 11, 2013 | 08:07 AM
BLAQ&GREYs2k's Avatar
I am looking into doing gauges as well and the three I think would be most beneficial are Oil temp, water temp, and oil pressure. Havnt done much research but a quick google showed me glowshift.com which has an oil filter adapter that has inputs for the gauge oil temp and pressure senders without having to drill into your oil pan, etc.
Old Jun 11, 2013 | 08:10 AM
kenta's Avatar
I have a set of Defi Racer gauges in a SOS pillar pod. What I like about them is that they don't require a control unit so installation is fairly simple. My only gripe is that the stock wire that comes with the oil pressure gauge is a tad short. It would probably be fine if the car was RHD, but state side, with the pod on the left side I needed a longer cable to get to the sender location. Defi sells an extension for $$, so I just snipped them and extended them myself fairly easy. For aesthetics I removed the black bezel, it just pops off, so there is just the silver accent ring which matches very nicely with the 2002 black interior which has silver accents around the tweeter speakers. Flows nicely IMHO.
Prior to that I had ProSports. You get what you pay for. The boost gauge would randomly freak out. The oil sender died after 1 year of use. Ditched them for Defi and never been happier.
Old Jun 12, 2013 | 03:48 PM
Cody Red's Avatar
I highly recommend SPA gauges. Just put on my oil/water temp (they are 2 in 1 gauges) and they work great. multiple color variations, overall nice design. the prices seem steep but you're getting what you paid for plus it's two gauges.
you can get them at scienceofspeed.com
Old Jun 12, 2013 | 08:18 PM
also does anyone make the 3 gauge pod for the s2k. Right hand drive. SOS make a double gauge pod.... anyone have any info on a 3??
cheers
Phil
archtop
Jan 6, 2009 05:49 PM
S2k1807
Jan 8, 2008 06:27 PM
BigBodyS2K
Mar 31, 2004 06:07 AM
beroznikmal
Feb 25, 2004 01:45 PM
marcucci
Jun 23, 2001 06:21 PM
