Sponsored by: CARiD
Modifry Redline Shift Beeper
Old Oct 30, 2008 | 09:17 AM
  #41
Nick.'s Avatar
Originally Posted by daktruckie99,Oct 30 2008, 05:18 AM
You can shift prior to the RPM, or if you really want it off for a long period of time you can set it to AP1 revs that your AP2 will never reach
hahahahaha
Old Aug 17, 2015 | 08:17 PM
  #42
Jason B's Avatar
I know this is older, but for those that have the Modifry shift beeper, have any of you had issues with it overtime?
I got mine a long time ago. It has worked great and I love it. Recently it will stop working outta nowhere, and at the same time it does, I have a RSX sub woofer that's connected to the battery with a fuse and that stops working at the exact same time. Eventually or a couple weeks down the road both will start working again. I don't know how this is tied together. Any ideas?
Old Aug 18, 2015 | 07:34 PM
  #43
schhim's Avatar
I've never had a problem with mine. I'm no electrician so I'd be guessing if I told you anything.
Old Jun 7, 2018 | 02:35 PM
  #44
Jason B's Avatar
Anyone?
Old Aug 6, 2018 | 08:36 PM
  #45
Jason B's Avatar
Any ideas?
Old Aug 6, 2018 | 10:00 PM
  #46
Kyle's Avatar
Sounds like you have an intermittent ground issue somewhere. I'd check the wiring for everything.
Old Aug 8, 2018 | 05:05 AM
  #47
Car Analogy's Avatar
Where did you tap power for both?
If you add a new outlet in your garage for your battery charger, and you tap into the wiring from the kitchen which happens to be on the other side of the garage wall, then it should be no surprise when the dishwasher and the charger both go off at the same time when there is an issue with your wiring work, even though those two things have nothing functionally to do with each other.
It should be clear that there is nothing wrong with either the sub or the beeper, but rather with their shared power supply (or ground, which is really just the negative power lead).
Old Aug 8, 2018 | 05:28 AM
  #48
freq's Avatar
^^^ Smuckin Fart
sn0wman
Mar 9, 2012 06:20 AM
OhioRacer
Nov 5, 2010 01:51 AM
chuhsi
Aug 22, 2007 12:13 PM
whaler167
Nov 11, 2005 08:42 AM
