Sponsored by: CARiD
MODIFRY SHIFT beeper
Old Jun 9, 2010 | 12:06 PM
SRap1's Avatar
Default MODIFRY SHIFT beeper
Just installed the modifry shift beeper, got it working... starting messing with the settings.... turn everything off, and started to relocate the speaker/beeper, after installing it the thing wont stop squealing.
As soon as the key is turned to on it starts squealing non stop. also my abs eps and check engine light flash.
any ideas? i checked all the connections, and sent an email to modifry, just wanted to see if anyone on here could help.
Old Jun 9, 2010 | 03:00 PM
wisdom's Avatar
I know you mentioned that you checked the connections, but the only thing I would deem plausible is a wrong connection somewhere.
Old Jun 9, 2010 | 03:22 PM
ans2k's Avatar
I agree. It could be the wrong connections. I reversed the connections where the wires attach to the modify unit. And it started beeping like crazy randomly. Then I unplugged it.
But go over ur connections again
Old Jun 10, 2010 | 02:30 AM
SRap1's Avatar
yeah i checked all the connections again and cant see where its wrong, it worked fine before, i just unplugged the beeper, extended the wires and then it went crazy.
Old Jun 10, 2010 | 03:06 AM
nickp's Avatar
mismatched wires when you extended it bad connection or ground? gl
Old Jun 10, 2010 | 06:56 AM
josh7owens's Avatar
yea bad connection. soder all your connections
Old Jun 10, 2010 | 07:36 AM
SpitfireS's Avatar
Did it work after "messing with the settings" and before relocating the speaker?
Old Jun 10, 2010 | 04:55 PM
s2k aok's Avatar
quadruple check all the DIYs...
Old Jun 11, 2010 | 02:23 AM
SRap1's Avatar
i used the supplied t-taps im sure there on there good, i didnt want to cut any of the wires completely. i think the actual unit may be bad. when its plugged in and squealing its causing my EPS and ABS lights to blink!
mikefifth
Nov 24, 2014 01:19 PM
angustav
Jun 23, 2010 11:10 AM
Greg W
Dec 11, 2008 10:29 AM
Jason B
Jul 9, 2005 07:38 AM
chriztopherkent
Jul 21, 2004 06:55 AM
