Sponsored by: CARiD
Rear Quarter Panel Question
Old Jan 15, 2019 | 09:30 AM
juno1996's Avatar
Default Rear Quarter Panel Question
Working on a left rear quarter panel replacement. Does anyone know if an AP2 panel will work with an AP1 (specifically year 2000)? I noticed the part numbers differ slightly (63300-S2A-300ZZ vs. 63300-S2A-310ZZ). Would hate to find out the hard way they are incompatible.
Side note: If anyone has a left rear panel, please let me know!
Old Jan 15, 2019 | 02:28 PM
Deckoz's Avatar
pretty sure bumper tabs are different, otherwise identical
Old Jan 15, 2019 | 09:02 PM
jiepo's Avatar
The holes for the taillights will also be different I believe
Old Jan 16, 2019 | 04:49 AM
Deckoz's Avatar
pretty sure thats a different panel, #15
seam sealer goes between quarter and rear panel for tails.
The bumper tab I was talking about its bottom side of quarter up close to the wheel. Otherwise should be identical.
Old Jan 16, 2019 | 08:05 AM
Car Analogy's Avatar
...so if you can't get the correct panel, perhaps you can meld old panel and new for these areas that are different. If those areas on old panel aren't damaged.
Or make a template off the good panel on the other side of car, then flip it to create a mirror image, to use to make a sort of patch panel for the correct taillight mounting holes.
Old Mar 8, 2019 | 12:23 PM
Uglyobesegamer's Avatar
I just did this, it worked perfect. I keep the AP1 tail light holes on the car.
Stoatmaster
Jun 26, 2013 09:31 AM
Mongo84
Oct 17, 2012 11:27 AM
cyber_x
Jan 21, 2003 04:34 PM
